Re: Leaking seals
Posted by Patrick Martin on July 29, 2007 at 17:11:02 from (64.154.26.250):
In Reply to: Leaking seals posted by Hand Crank on July 29, 2007 at 10:26:06:
When you install the new seal be sure to coat the outside metal side with gasket sealer. It helps if the metal surfaces are pitted or warped. Be sure to slip fit the new seal before you install it too. If it is something like the front crank seal then you'll have the timing cover off anyway. Clean and polish the crank end up with a fine emery paper and coat it with oil. Lubricate the seal and slide it on and test how it fits on the shaft. Sometimes those old felt seals, when full of dirt and goo, will hold abrasives like dirt, sand and itsy little rocks that will wear down the shaft and cause a dip in it. If you find that the new seal just barley grabs in that area then go to a seal shop and have them find you a better fitting seal OR take a ball bearing and set it in the backside of the seal after it is installed in the front cover and tap it with a hammer all of the way around the circumference of the seal. This will spread it just slightly and take up a little of the slack but it will only take up a couple thousandths if that and you have to be careful to not get it out of round too.
Home
| Forums
Today's Featured Article -
Oliver 550 Clutch Overhaul Tips - by Greg Sheppard. I got my 1964 Oliver Model 550 (serial 141-139-519) second-hand and used it for several years before the clutch began to slip. After taking up the pedal linkage several times I saw it was going to take more than that. The engine had been leaking oil at the rear seal and I suspected
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
