Re: IH 240 hydraulic 3pt hitch, float mode - one way
Posted by georgeky on August 14, 2007 at 12:58:10 from (205.188.116.73):
In Reply to: IH 240 hydraulic 3pt hitch, float mode - one way posted by Larry A K on August 14, 2007 at 10:51:43:
If it has the external lift cylinder like on a Fast hitch changing to one way will NOT make it float. There is a pin on the bottom of cylinder mout that needs to be removed to do this. Need to see that pic to be sure. If it is like this I have a pic of the pin position I could send you if you email me.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
