Re: noise
Posted by Janicholson on August 15, 2007 at 17:19:42 from (66.173.50.167):
In Reply to: noise posted by deane ferrish on August 15, 2007 at 07:57:04:
If the "clunk" happens a few times a second, it is probably one or more broken teeth in the tranny. Fifth is a coupling direct drive through the input shaft to the output shaft, but fourth is on that fork. I would first pull the belt pully, or belt pulley port cover if no belt pulley, and look at the gears from there. the oil may cover much of what you see, so draining firat, and letting it drip off for a day might enhance your view. Both the driven and coast side of every tooth needs to be looked at. Not all the gears can be seen from the pully opening. If fourth is clicking, and chipped, I would fix it pronto. Reverse might incline me to put it off unless it is used in reverse a lot (loder etc.) JimN
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
