Posted by Bob M on August 22, 2007 at 08:32:37 from (151.190.254.108):
In Reply to: M - H Compatibility posted by Robert Heft on August 22, 2007 at 08:20:08:
No way Robert! The only thing shared between between the H and the M engine/drivetrain is the color of the paint. (Virtually EVERY part on the M is a good 30% bigger in size...)
It would require a major machining effort to graft your M engine onto the H rearend. Your time/$$$ will be much better spent sorting out your M's transmission problem!
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
