Posted by Idaho Ron on August 25, 2007 at 14:44:45 from (208.98.154.197):
The 100 dollar SC had a nasty looking top link mount. This is what it looked like. These are arms that bolt to the Axel housing. They were not real good and moved around a lot. No way to get them tight enough.
I decided I need to do something different. Here is what I have now.
I made the plate out of 1/4" steel. The eyes are 1/4" thick Hammermill hammers. I used the stock bolts to put it in place and the top bolts are 1/4"x5" I put 1/4" pipe in between the plate and the seat. The pipe is to keep it from flexing at all.
Question, how much can I lift using this? The way the old one worked this one is much less able to move around.
The most I would lift is a brush hog, blade, and maybe a corrugator. Ron
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp
... [Read Article]
