Sounds like you have a good one! I have a late '52 SM, and like it a lot.
Before you go to the trouble of a complete rebuild of the front bolster, check three places for wear that may be part of the front wheel wobble. 1) That little bearing behind the castellated nut is easy to replace and often badly worn. It can allow a lot of wobble. 2) Bad front wheel bearings can cause the shakes, also. Run one front tire at a time up on a block of wood and shake the other one to check for wear. 3) Check the universal joint just above the front of the gas tank. It's another prime suspect, and easy to change.
I'll echo what some others have already told you, be careful if you start messing with those loaded rear tires. Also be advised that removing the water and CaCl from the rears will raise the center of gravity, allowing the tractor to tip more easily.
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
