Before you tear your tractor to pieces, check the simple stuff first. If the timing gears were the problem, you would not be getting a spark, let alone a spark that's "on time." The crank gear drives the cam gear, and the cam gear drives the distributor, so if the distributor is turning, the cam is turning.
Sure, there is gas in the tank, but is it getting to the carburetor? If it's getting TO the carburetor, is it getting THROUGH the carburetor?
Have you pulled the oil cup off the air cleaner?
Have you pulled the air hose off the carburetor intake? Does it have good suction when you crank the engine?
You can pull the valve cover off easily. See if the valves are moving.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
