First off block the clutch pedal down. Then as the other guy says drive it around in as high a gear as you can which menas starting it in gear or jamming it into gear. Or this also works some times. Pull the starter off and spray brake cleaner into the clutch area with the pedal blocked down, turn the engine a little at a time so you get the whole clutch area.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
