Re: governor trouble
Posted by Clarkbug on September 30, 2007 at 07:58:22 from (72.83.168.59):
In Reply to: governor trouble posted by H fanatic on September 26, 2007 at 15:59:59:
What part of your manifold had to get brazed? Is it possible that your carb was adjusted to have the tractor run with some air getting in after the carb?
My thought being that if you have plugged up the air leaks in the system, you need to readjust your carb/governor for the new setup?
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
