Re: FARMALL 504 GAS ENGINE SWAP
Posted by Hugh Mackay on September 30, 2007 at 09:46:29 from (209.226.106.6):
In Reply to: Re: FARMALL 504 GAS ENGINE SWAP posted by richhenry on September 30, 2007 at 04:59:22:
Rich: I don't know the part numbers for any of these larger engines, however after 1954 all IH four cylinder gas engines had displacment cast into the block as in C-123 used in offsets 200, etc. C-135 used in 404, C-153 used in 504, C-169 used in 300 and C-175 used in 350. These numbers are cast on right side of block, as I've typed it. All these engines were sleeved except the C-153.
I think Hal pretty well nailed the reason; C-123, C-135 and C-153 are all the same block, just bored larger. The C-169 and C-175 are the same block but much heavier than the smaller block, lot more steel in them, basically the main reason why they are a better engine for 35 to 45 hp.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
