Posted by ScottyHOMEy on September 30, 2007 at 17:17:34 from (71.241.214.74):
In Reply to: Water in the Oil posted by 3RD Generation IH on September 30, 2007 at 16:37:40:
A BIG question there. Could be a lot of things.
Head gasket is an obvious place to look. On the old Farmalls (maybe on all engines, I don't know) it was always recommended, after putting a new head gasket in, that you get the engine running good and warm, and then retorque the head. Sometimes, but not always, pulling the head will show you a spot on the head or the top of the block where the coolant got across into your oil.
But that much fluid suggests the problem could be a crack in the crankcase further down. I know it was a long time ago, but can you recall if there was a similar problem when you drained the engine before the rebuild?
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
