Posted by slowfolk on October 01, 2007 at 09:59:38 from (69.24.160.98):
In Reply to: Water in the Oil posted by 3RD Generation IH on September 30, 2007 at 16:37:40:
Had the same problem with a Allis Chalmers WD45. I would check the oil on a regular basis and notice the the oil was coming up higher on the dipstick. After talking with others on this site I started removing the head first, nothing appeared wrong, then the pan, the first thing I seen was antifreeze dripping from around the sleeve on the rear piston sleeve. Removed that sleeve and found the orings from around the sleeves deterioated causing a leak.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
