Intermittent Miss
Posted by Brian Jensen on October 03, 2007 at 14:53:49 from (207.176.229.92):
Got everything back together again.... I seem to have an intermittent miss, there is absolutely no pattern to it at all. Could this be a distributor shaft wear issue? Since I have the timing set amongst the million other things I have done in the past 2 days. It seems to Want to start and stay started it just won't for some reason. Also when this miss occurs it seems to actually bog the starter down where it kind of hesitates due to the pressure. Again, all suggestions are appreciated.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
