The one you are talking about is an early model. Later on they would install the bell housing for a starter whether or not it would leave the factory with a starter and just put a plate over the hole. Yours probably doesent have the flywheel machined for a ring gear either. So if you want a starter you will need to split the tractor of course but before doing mite want to look in the inspection hole on the bottom of your present bell housing to determine if the flywheel need changing also.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
