Andrew; I understand that there is rod for arc welding cast-iron...but I haven"t tried it on anything big or heavy. If you acetylene weld it (braze) you will need to heat the broken pieces up before welding...if you are unsure how to do it, take it to a reputable welding shop and let them weld it for you.Properly done, it should last a long time . Best of luck. Jim B.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
