The lift all has a relief (much lower than that, less than 1000psi) the lift all control rod can have a new little detent brazed to the under side to hold it back in the on position. As long as the valve you install is an open center device, when the valve handle is in the middle, it will be fine. When not using the hydraulic, it is probably good to put it back in the hold position of the stock detent stub. Plumb the return line into the bottom drain plug with a T. the use of a T on the fill plug causes oil to come out the cap. If the devices use two way cylinders, and you check the oil as they get used to working, all will be fine. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
