Posted by John T on October 11, 2007 at 06:33:26 from (66.244.83.147):
In Reply to: 350 turns over very slow posted by charles hoffman III on October 10, 2007 at 21:28:49:
BEFORE you suspect the starter, Id FIRST remove, clean n wire brush, then reattach each n every battery n starter n switch/solenoid n frame ground conenction n see what happens. If the frame ground is to any thin or rusty wimpy sheet metal, try it direct to a heavy frame member. I like 00 cables on 6 volt and 1 or 0 on 12 volt applications, wimpy 4 gauge drop too much voltage slowing the starter. You might wanna remove n clean n wire brush where the starter mates to the tractor in case its getting a poor ground.
If youre SURE the battery is good (try a known good substitute or have it load tested or jump it) and allllllllll cables n connections n grounds are good but she still cranks slowwwwwwww, if you can get to all the starter/switch/solenoid connections using good tight heavy jumper cables without arcing or shortign out you may wanna by pass jump around the switch or solenoid n see how she cranks then to see if the switch or solenoid has a problem IE jump direct from the hot ungrounded battery post to the starter input (switch/solenoids output) n see if she cranks betetr indicating a bad switch/solenoid.
FINALLY if alllllllll cables n connections n grounds and battery n switch/solenoid isnt the problem, then I suspect the starter, ASSUMING the engine isnt bad or binding?????? See how well she cranks with the spark plugs removed n no compression ???? Engines not over tight is it???
I ask all this cuz its often just a simple problem like a cable or conenction or ground or battery or switch/solenoid instead of a starter.
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
