Re: 350 Hi Utility Next Problem
Posted by CNKS on October 28, 2007 at 09:11:40 from (216.144.104.128):
In Reply to: 350 Hi Utility Next Problem posted by Pat in Wisconsin on October 28, 2007 at 07:09:20:
If you work alone, invest in an engine hoist. For safety (those hoists can tip over), remove the rims from the centers. Then the wheels can be removed safely and relatively easily. I believe you can remove the cap and pull or carefully dig the seal out. Just don't score the place where it fits. On the tractors I have done, I also replaced the gasket between the axle housing and the rear end--may not be necessary in your case, but I have never tried to remove one with the axle in place. Gaskets/seals don't come in a set. They can be purchased from your Case-IH dealer, the seals are likely cheaper from a place that specializes in bearings and seals, but the cap seals aren't expensive, anyway.
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
