Re: SA hydraulic pump seal question - where does leaking oil
Posted by georgeky on November 04, 2007 at 07:41:44 from (64.12.116.73):
In Reply to: SA hydraulic pump seal question - where does leaking oil go? posted by SteveNH on November 04, 2007 at 06:50:00:
If it is leaking the oil goes into the crankcase. If so your engine oil will be overfull. The whining can be caused by lift box being out of adjustment. It is critical that it be adjusted properly. If you can't do it, you should have someone who can look at soon. This is covered in the IT manual under stop clip adjustment.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
