Re: SA hydraulic pump seal question - where does leaking oil
Posted by Gene-AL on November 04, 2007 at 08:04:09 from (74.242.20.239):
In Reply to: SA hydraulic pump seal question - where does leaking oil go? posted by SteveNH on November 04, 2007 at 06:50:00:
Steve,
When you have a bad seal on the hydraulic pump input shaft, Hy-Tran fluid leaks past the seal into the engine crankcase. I had that problem on a SA several years ago, engine oil level rising, hydraulic fluid disappearing from the unit. Put in new hydraulic pump seal, problem solved. Not a complicated job (if I can do it).
If you drained and installed new fluid, you may have had air trapped in the system while filling and after the air was purged by operating the lifts the fluid level may have dropped to replace air pockets.
Proper fluid level is to the bottom of the fill plug opening, but I guess you knew that.
Be careful taking the fill plug out - sometimes there can be air pressure behind it.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
