Trickle Charger on 43' H
Posted by Wisconsin_Joe on November 05, 2007 at 12:13:08 from (67.142.130.24):
I am having an issue with a trickle charger I installed on my H that has a 12 volt conversion. When I plug it in it never stops drawing the trickle charge. So it is not really maintaining but running constantly and it never kicks off. I put my big battery charger on the battery it charges to about 14 volts and kicks the trickle charger off like I would expect. I remove the charger the volts drop to about 12 volts and the trickle charger kicks back on in a few seconds, never to turn off again I fear. Do I need a new battery? Or is something else wrong?
Thanks
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
