Are you using an actual guage, or are you going by the idiot light in the dash? Keep in mind that on an 06 series tractor, the idiot light is for both engine oil pressure and transmission pressure. If you're holding the clutch pedal down, the MCV dump valve will be open to dump oil pressure out of the TA clutch, causing trans pressure to drop and the light to come on. This is normal. Could also be a MCV problem. Eliminate this possibility by disconnecting the trans pressure sender. It is located on the rear side of the MCV, which is located on the left side of the clutch housing. Now, if you're using an actual gauge and you have no pressure, try Jim's method of priming the oil galley.
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
