Re: Need help on brake bearings on my 43 H
Posted by Eastsider on November 29, 2007 at 07:50:33 from (204.73.192.210):
In Reply to: Need help on brake bearings on my 43 H posted by neblinc on November 29, 2007 at 06:43:29:
It is an involved process...however, with the transmission top off
already you are about half done...you will need to remove both
axels and housings so the bull gears can come out...it is a great
time to check the bearings all over then...new gaskets for the
axel housings are probably needed anyhow, so while you are
there.....After removing the bull gears, then you can unbolt the
pinions and differential and take it all out to inspect and repair.
mark
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
