Glen, best I remember those panels are ribbed. Never seen one with anything other than a 4 speed. It is quite different than the 2444. The 240 is closer kin to the SC/200/230 and so on. Uses the same C-123 engine as SC. Rear end is similar as well. Does have bar grill like 560's. I bought one in pieces and put it back together a few years back. If I remember correctly it uses the same gears as a 140.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
