Mike you will have no problem with the 12 volt on the OO cables that will have a great connection!! As for the gauge iv used all the gauges that were 6v for the 12 volt systems. I belive that this is due to there amp. gauges and they measure amps and not voltage. Sooo i think your good to go!!
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
