You will probably have trouble finding 0 or 00 gauge, I don't think anyone stocks them in the boonies where I live. I don't think it gets very cold where you live, that is what requires the most amperage. If not, 2 gauge will be fine. I think most 12 volt systems have 6. My 6 volt Super A still at least one of the 6 gauge on it that were there when I purchased it -- It starts easily in warm weather, forget it when it gets cold. Most battery/cable problems are caused by lack of use. If you start it occasionally and keep the connections clean you will have fewer problems. 12 volt allows you to get by with less maintenance than a 6 volt system requires. Large cables allows you to get by with less maintenance on a 6 volt system, so you are kind of working around the problem, i.e. maintenance -- I don't like to do it either.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
