Posted by Nat 2 on December 28, 2007 at 10:14:27 from (64.80.108.52):
In Reply to: Battery cable question posted by perrycountyfarmalls on December 28, 2007 at 07:10:04:
Ohm's law is double the volts, DOUBLE the Amps if you use the same 6V starter. You get FOUR times as much power going to the starter. That's why a 12V conversion spins the tractor over so much better.
Mike, thicker cables are ALWAYS better. It doesn't matter what voltage you use. Thicker cables offer less resistance to the flow of electricity.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
