You should be able to get 1ga from NAPA keep it original as there was no solenoid just a sw with large button going to the post on the starter from the sw this casble would have an eye on both ends the one from the batt to the sw would have one end for the battery and other end going to the other post on the sw. If you have trouble getting the starter sw go to CAR QUEST as they have them. Our dealer has them in stock. You sure dont need 12v in CALIF as warm as it is there. MY Bthat i plow snow with starts at even below zero with a 123hi dome engine.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
