Posted by Horse-George on February 03, 2008 at 22:55:05 from (204.73.103.253):
This message is a reply to an archived post by Bob on October 22, 2007 at 19:25:07. The original subject was "WOW... Lets get this fixed".
Hello
I just looked at this page and found a partial answer to my question, which I posted a short while ago. From your photo, I can see I have three options, a resistor, a bulb, or a diode going to the alternator exciter terminal. After seeing what you posted, I think the original plug that came with my Farmall H must have had the diode. It was molded onto the top of the alternator pigtail plug, and embedded in some sort of rubberized material. Because of this I was unable to see what it was. It burned out and I thought I needed a resistor.
In my post, I mentioned that I have been using a bulb on the side of the engine block but I keep breaking it. I did not know what size resistor to buy, and no parts store could help.
Since you mentioned the overheating of a resistor if the IGN is left on, I know I did not have a resistor, since I have left the IGN on far too many times and nothing ever got hot or melted. I bet it was a diode embedded in that rubber goop.
You show a 1N5408 diode. I know electronics, and how to use a Diode, but where I live, we do not have any electronics stores unless I drive 50 miles to the city and go to Radio Shack. So, I need to know the specifications for that diode. Radio Shack usually only rates them by volts and amps, and no actual part number. What do I need as far as volts and amps? Is the part critical, in as much as can I use any diode that is at least whatever amperage I need, and can handle at least 20 volts or so? I am asking because I have lots of old tv chassis with rectifier diodes, which wont cost me a cent or a long trip to the city.
One other thing. I noticed that many of the discussions on here mention that the tractors converted from 6 to 12 volts need a block resistor to the ignition coil (like in the old Chrysler cars). My coil does not have one. However, my coil is a 12V coil from a 12V car (I replaced it when I bought the tractor because the old one was arcing thru a tiny crack). Should I still have one, and why? It almost seems senseless to buy the resistor, mount it, and wire it, when 12V coils are a dime a dozen at most auto junk yards.
By the way My neighbor has a Farmall 400, and he has that resistor on his. His tractor was also converted to a 12V system. I dont know if he has the 6 or a 12V coil (they all look alike).
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
