Posted by georgeky on February 10, 2008 at 09:44:06 from (205.188.116.73):
In Reply to: Re: SC and dual wheels posted by Hugh MacKay on February 10, 2008 at 00:33:00:
Hey Hugh, I agree a SC with a C-135 would have been a nice one, but it still doesn't change the fact that it was designed for, and will handle a 2 X 14 inch plow in any ground. I have plowed 100's of acres with them. will pull that plow 10 inches deep in tough KY fescue sod in 2nd gear.
Dad has a 140, and it spins and bucks with the cultivator or 1 bottom plow in the ground deep here. Now I am basing my assesment of each from years of use of each. My SC will spin the tires with weights on it, and the 230 dad had was a bit stronger than my SC is. My point is that you can not run down something based on the very limited experience you have had with it. I used a SA once that wouldn't pull the hat off your head, but that didn't make all of them junk. Have a good one.
Today's Featured Article - Fabricating Sidesheets - by Chris Pratt. The easiest and best first-time project for wanna-be sheet-metal workers like myself is flat or nearly flat metal cut and drilled to be a tractor's sidesheet. A sidesheet is sheetmetal to cover either the engine as in the case of early Oliver's, Massey-Harris' and many crawlers or the wiring and electrical components as in the case of the Massey-Harris Pony, Allis Chalmers' D Series (D-14, D-15, D-12, D-10, D-17, and D-19). The need for fabricating becomes obvious when you go to buy any of these
... [Read Article]
Latest Ad:
[More Ads]
