Posted by Andy Motteberg on February 16, 2008 at 12:51:32 from (4.143.221.235):
In Reply to: H on Steel posted by Greg-N-CA on February 14, 2008 at 19:35:53:
Greg,
That Farmall H looks EXCELLENT! I see below you said it is a 1943, I have a 1943 H too, serial# FBH-133801, my H originally had steel on the rear, but it was changed to "cut-offs" later. You should get that H right away... not many around on full steel and none of the electrical stuff. You should also try to get that F-12 Farmall that is beside that H!
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
