Given Ricks number for offset, if the surface was not milled and is foundto be close to 1.406 + or - .005", the clutch should work fine. If the wear, or machine work were only on the friction surface and not the mounting edge, the lever movement you observed would have been greater. Clutch disks wear thinner, so does t both the surfaces of the flywheel and PP that touch it. eventually allowing the pedal no free travel unless adjusted. The pieces that wear in the other direction (increasing the freeplay) include the fingers that touch the throwout bearing, The throwout bearing, the pivot points of the clutch relief shaft, the clevice and link pins that operate the Throwout system, and the pedal bushings. If these systems ake kept lubed, the pedal will work toward no freeplay, if not the whole system can wear such that the freeplay seems to stay the same. I hope this explanation helps take the mystery out of it. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
