Re: tractor won't run
Posted by Patrick Martin on February 25, 2008 at 20:14:11 from (64.154.26.250):
In Reply to: tractor won't run posted by Farmboy835 on February 23, 2008 at 19:11:45:
OOH!
Something comes to mind here with something I did with the wiring.
I somehow wired the darn thing to where I was getting no spark when I put a load on the starter or vice versa.
Have someone check the fire as you turn it over and check to see if the coil stays energized when you let go of the switch.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
