Re: 1486 Diff Lock
Posted by Iagary on March 10, 2008 at 03:44:19 from (67.55.192.138):
In Reply to: 1486 Diff Lock posted by DLJ on March 09, 2008 at 21:04:46:
The diff lock is to lock the rear end so that both wheels pull at the same time. Just as positraction does in a car.
If one wheel gets to spinning in a slick spot you can hit the diff lock to get the other side to help pull through and help from getting stuck.
You could do the same by tapping the brake on the wheel that is spinning. But if you tap to hard that wheel will stop and the other will spin.
Diff lock makes them both pull even.
Gary
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
