As the others indicate, it needs to be checked with a volt meter to make sure it is actually charging. A good battery will run a Farmall/IH for as much as week of use before failing to start. If the gauge reads "0" with nothing on, then if the lights are turned on, it reads discharge, and if the tractor is running at 1/2 throttle or above, it still shows discharge, it is in need of repair. Use the search for box above for finding John T charging system steps. THat in concert with Bob M wiring diagrams are the eventual answer. JimN
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
