Posted by mkirsch on April 09, 2008 at 04:58:00 from (64.80.108.52):
In Reply to: 1939 H Hydraulic Oil? posted by gene bender on April 09, 2008 at 04:32:30:
gene:
The upper ends of the cylinders are probably being used for auxiliary reservoirs. A belly pump doesn't hold enough oil to raise most one-way loaders all the way up without going dry.
This was VERY common with those old "straight arm" loaders with the really long cylinders.
As the loader is raised, oil is pushed out of the tops of the cylinders and into the belly pump through the fill pipe. When the loader is lowered, the excess oil is sucked back into the tops of the cylinders.
Tom B:
You do NOT want the return line on the bottom of the sump. Leave it where it is. Otherwise, the belly pump reservoir will never be full. Here's why:
Because the cylinder shafts are taking up some room inside the tops of the cylinders, there will never be as much oil coming in as going out as you raise the loader. If you raise the loader and refill the reservoir, the loader won't go all the way back down for the same reason.
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
