Posted by ihc49 on April 20, 2008 at 20:03:19 from (216.123.197.160):
In Reply to: MD 9 posted by Red Bob on April 20, 2008 at 18:51:07:
MD9??? no such thing. must be WD9 or TD9.but anyhow it seems you want to bleed the fuel system.just bleed the primary filter,and secondary filter.if you need to, loosen injector lines at injectors to bleed pump and lines.the flip cap on top is for engine oil.the pump holds about 2 cups of oil.the 1/8 plug on btm is the oil drain.you change this oil at same time as engine oil, or sooner as the transfer pump seals usually leak diesel in here.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
