Re: 856 Axle housing and Brakes....
Posted by minnesota red on April 27, 2008 at 20:24:03 from (74.33.24.132):
In Reply to: 856 Axle housing and Brakes.... posted by Dan Swanson on April 27, 2008 at 07:49:08:
if you pull the plugs out of the axel tubes on the bottom and drive it around it will drain the whole system.
It is common practice to run the older IH rears over-full on oil when doing PTO work in the hills to keep the oil level high enough so you don't take the PTO out.
this will also over fill the axel tube,as I recall their is a 1 1/2 inch hole for the oil to drain back into the rear and a 1X2 hole from the rear to the trans.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
