Re: ihc 400 ipto brake band adjustment
Posted by pete 23 on March 07, 2009 at 17:25:09 from (173.87.1.12):
In Reply to: ihc 400 ipto brake band adjustment posted by cob_crusher on March 07, 2009 at 15:37:03:
You can do a proper adjustment procedure following the book or just turn the adjustment screw nearest the tractor in until you have about the width of the pawl tension when engaged. . The marks they are talking about are just so you put the pawl half way between disengaged and engaged, turn in both screws until snugged down, and then back off, I think it is 1 1/2 turns. Should be able to turn shaft with a short punch through hole in shaft when it is in middle position. ( screws are under the little cap on top and probably rusted) pretty cut and dried.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
