Posted by glennster on June 01, 2008 at 17:51:40 from (68.60.242.156):
In Reply to: 1950 FARMALL M posted by HIGHLANDERSCOTT on June 01, 2008 at 17:43:51:
to remove the steerig shaft, you need disconnect the shaft up near the tem and oil pressure gauge. there should be a u-joint there with a bolt. take the bolt out and spray up the shaft with penetrating oil. if it has power steering, ie char-lynn, there is a roll pin you need to drive out. next unscrew the big pipe plug cap at the front of the top of the steering bolster, once out the shaft will unscrew out of there. you should be able to get the two lower mounting bolts for the radiator out without dropping the front axle. yours may still have the mud shield under there. you also need to unbolt the cooling fan shroud from the radiator, and set it back toward the engine to get the radiator to clear .
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
