Posted by ironhoarder on June 07, 2008 at 07:17:23 from (208.72.77.15):
As I posted a few days ago, my 1963 806 suddenly developed a noticeable engine knock while basically idling and doing nothing in particular.
The engine was at a fairly low RPM and when putting it into gear (but before letting the clutch out), a new knock sound started in the engine. Not a catastrophic sound, just a bit of a knock.
The problem is that I need to finish taking in my hay and I have another 20 acres to cut and bale with this tractor.
An IHC mechanic friend suggested (without hearing it first hand) that it might just need rod bearings, and that is a very easy job.
So- what to do- just go ahead and do my hay and deal with it afterwards? Or take the time now to pull the pan and at least inspect the rod bearings (look for wiggle I guess)? Or just assume that it is gonna need a full rebuild- there is a bit of blow-by coming out the bottom of the engine- not terrible, but some.
The engine has definitely seen a lot of use, but seemed pretty decent when I bought this a month or so ago.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
