Re: Farmall M with stuck motor
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by p on March 13, 2000 at 15:07:20 from (12.33.190.5):
In Reply to: Farmall M with stuck motor posted by Venda2 on March 13, 2000 at 14:44:03:
are you sure the starter is not wedged into the flywheel. I would pull off the starter and make sure it is free and then see if a big screwdriver will turn over the motor a bit(if you have a hand crank use it instead)
Post A Followup
: Re: Re: Farmall M with stuck motor
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
