If chanding the filter and what not doesnt make a difference it most likely sounds like th pump is the problem, or a blocked or clogged line between it and the valves, or in the valves themsevleves. Could also be worn o-rings on the pump or supply tube. The other thing that happens is the constant running shaft drving the pump will wear, or strip out, but than the hydraulics usually go out all together. Let us know how it goes for ya.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
