The original spark plugs were either D16 or D15Y. International started with the D16's and then changed to one heat range colder with extended tip. That is the D15Y. For light duty the recommended plug was a D18Y, still extended center electrode but a few heat ranges hotter. With the phasing out of leaded fuel the recommended standard duty plug became the D18Y and D21 for light duty.
For tractors still being used at full load most of the time the D15Y will still work. For moderate usage a D18Y should be used. For light duty use, or if you are having fouling problems with D18Y plugs, use D21 plugs. Do not use D21's if you are going to doing something like plowing of disking where the engine will be running under for load for an extended period of time. They will start to run too hot and can lead to engine damage due to preignition.
The threads for spark plugs were changed to metric sometime in the twenties or early thirties. 14mm is the most common but Ford used 18mm for quite a few engines and I've seen some old GMs from the thirties and early forties that used 10mm threads.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
