Posted by John T on June 20, 2008 at 05:35:08 from (66.244.97.31):
In Reply to: super c VR issues posted by mazemeister on June 20, 2008 at 03:16:36:
Maze, I dont think its any third brush adjustment problem, cuz if she charges that well with a dead grounded Field that says the genny (including wherever its third brush is set) is fineeeeeeeee PLUS the gennys ground is fine. I agree with my buddy the Bob M, before tossing the VR make sure it has its own good ground by jumping its case/frame/metal to a good ground n see if charge improves??? (also check n clean the VR's F terminal to gennys FLD post wiring for a loose or resistive connection) If not you may be able to non abrasively as possible clean/buff/polish the VR's field control relay contacts cuz they may be burned or carboned n resistive, worth a try (grounding and cleaning).....
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
