Posted by mazemeister on June 20, 2008 at 07:05:26 from (24.188.81.230):
In Reply to: Re: super c VR issues posted by mazemeister on June 20, 2008 at 05:07:05:
the D-R tag on the genny says 1100501 4?30 can't quite make out the ? digit, might be C,G,O, or zero. anyway the parts book lists 1100501, and a 3rd brush.
on the VR ground- tried a jumper wire from the little copper wire on the VR that goes from the base to the mounting tab, to the tractor frame- didn't help at all. the F to FLD wire idea sounds worth a shot- i'll see where i get with that. The new VRs these days don't have any adjusting screws for the spring tension, and it seems like the past few i've gotten were not set at correct voltage- so i guess they (NAPA or whoever) expect us to just bend the tabs to adjust?
Just did 2 hrs of cultivating, ammeter stayed right at -1 even at high idle. low idle dropped down a couple more. would that suggest the cutout relay also needs adjusting? I thought that was supposed to cut out to prevent discharge.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
