Posted by chadd on June 25, 2008 at 06:22:33 from (65.54.98.27):
Our Farmall M overheated out of the blue standing and idling a day or so ago. I added coolant and it only took a quart to bring it above the mesh in the radiator. It no longer overheats, but now it looses cylinders as it warms up. When I start it up, it will run on four, but has a miss. As it gets warm, cylinder 3 cuts out. Then after a while, another cylinder seems to quit. I did a compression test, and it had 85, 90, 68, and 88 psi on cylinders 1 through 4. It has the low compression Kerosene head (6336DD) When I turned it over to reset valves I swear could hear air blowing out on 3 and 4 through the pushrod holes in the head. Also, I see bubbles when I look in the radiator. I am guessing either a cracked head or bad head gasket. Do you think I can get away with just a headgasket, or is the compression low enough on all four that it should get a full rebuild?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
