You need to get yourself a good shop manual that covers your tractor. It should give you the step by step for replacing that seal. Your're probably going to need to remove the whole front end off that tractor just to gain access to the damper pulley. You will need to support the weight of the tractor since the front wheels will probably need to be removed. That seal has probably worn a groove into the hub on the damper pulley and will need a speedi-sleeve to cover that area so the new seal has a new surface to contact. Hal.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
