do like el toro said and run a compression test. run a dry one then wet. first pull the spark plugs and examine them closely, keep track of the cylinder they came out of . look for oil fouling, or wet plugs ect. next with the plugs out and throttle wide open, do compression test on each cylinder, and write the numbers down. they should be within 10% of each other, somewhere between 80-125 psi. then squirt 2-3 pumps of oil with an oilcan in each cyliner, turn motor over a couple times to spread oil around, then re-run compression test. if you get a big jump in compression, most likely rings are worn. if the compression doesnt jump or very little, look toward valves, guides and or seals.
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
