You need to check for fire to the plugs, pull off one of the plug wires and hold it near a good ground or 1/4" away from the plug while someone makes an attempt to start the tractor. No fire from plug wire check for battery voltage to the coil. Should have voltage on both terminals with points open and switch on. Clean the points with some 320 wet or dry. If they're pitted replace them and condenser. If you have a ballast resistor installed between the switch & coil it may be defective.
If there's fire to the plugs you probably have a fuel problem with dirt or rust in the gas tank or gas line. Remove the gas line at the carburetor and see if there's a full stream of gas. Hold a clean container to catch the gas. A trickle isn't enough. If there's a full stream of gas check for a screen behind that tube fitting for a screen. It could be plugged with crud. Be careful not to damage that fitting. Hal
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
